configure mlag ports reload-delay
configure mlag ports reload-delay reload-delay
Description
This command configures a reload delay on Multi-switch Link Aggregation Group (MLAG) ports.
Syntax Description
reload-delay Specifies creating a reload delay on MLAG ports.
reload-delay Specifies the MLAG port reload-delay timer in seconds (range = 1–1,200 seconds). The default is 30 seconds.
Default
The default reload-delay timer interval is 30 seconds.
Usage Guidelines
There are cases where MLAG ports comes up quicker than ISC ports after a switch reboot causing traffic loss during this time gap. This command allows you to configure a time delay for MLAG ports providing enough time for ISC ports/neighborship of other Layer 3 protocols to come up. To have this delay timer take effect, you need to issue the enable mlag port reload-delay command.
To stagger the bringing up of MLAG ports, use the command configure mlag ports reload-interval [none | reload_interval_msec]
To view the current selection for reload delay, use the show mlag ports {port_list} command.
The following example sets the reload-delay to 60 seconds:
# configure mlag ports reload-delay 60
This command was first available in ExtremeXOS 22.3.
Platform Availability
